Generation IV Internal Engine - LS3 7200rpm
Pete walsh
12-24-2008, 03:37 AM
As above what will I need to turn it so high??
So far I have GMPP Racing lifters.
Cheers
LS1LT1
12-24-2008, 03:49 AM
Better/stronger valve springs as well.
And this might be better off placed/asked in the Internal Engine section as well. :nod:
Pete walsh
12-24-2008, 04:22 AM
ahh poop sorry
LS1LT1
12-24-2008, 09:56 PM
ahh poop sorryNo biggie. :burn:
dlove
12-24-2008, 10:22 PM
i moved it for you.
get some katech rod bolts. and good valvetrain componets. I spun my ls2 with l92's on it to 7500+
njc.corp
12-24-2008, 10:28 PM
i moved it for you.
standard short with rod bolts?
dlove
12-24-2008, 11:22 PM
stock bottom end other than the katech rod bolts. also had ls7 lifters, comp pushrods, patriot extremes, and i even had the heavier l92 valves.
njc.corp
12-24-2008, 11:50 PM
Thanks for sharing-
not bashing- katech rod bolts vs arp?
venom ws7
12-25-2008, 11:23 AM
With good rod bolts and Valvetrain it sould be easy I spun my old LS1 with STOCK BOTTMEND all the way to 7200rpm
JFM-jr
12-25-2008, 06:09 PM
Same as the above post here. Stock bottom LS1 with Katech's needed 7200 to get thru the beams (and still touched the limiter set at 7200). My current project an LS2 will utilize another stock rotating assembly with good rodbolts.
In order have increasing hp up to that rpm you will need some special intake.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
