Help with shopping list if I get TR224 .563 112?
Since Thunder Racing is having a sale until the end of the month, now may be the time to take the plunge and get a cam.
(BTW, I have a pretty-much stock 2002 Camaro SS with aftermarket SLP airlid and LoudMouth exhaust.)
Q: If I get the TR224/224 .563/.563 112 LSA, what else do I need to buy?
That is, are new valve springs, retainers, or different push rods needed for this cam on a stock LS1?
What about a Valve Spring Compression Tool?
I see they have a cam swap gasket kit for sale -- guess I'll need one of those (or is there a better way to go?).
In short, what else do I need other than the cam?
Thanks! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Re: Help with shopping list if I get TR224 .563 112?
I see that Paul at Thunder recommended a while back:
Thunder Cam
Comp 26918's
Thunder Pushrods
What length pushrods?
Opinions on this setup?
Thunder Cam
Comp 26918's
Thunder Pushrods
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BigBlack2002SS:
<strong> I see that Paul at Thunder recommended a while back:
Thunder Cam
Comp 26918's
Thunder Pushrods
Opinions on this setup? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's what I'd recommend going with. The 7.400 pushrods will be fine with stock heads. Hope this helps...
Thunder Cam
Comp 26918's
Thunder Pushrods
I got the same setup but the cam is on a 114 LSA
I got the cam
comp 918's
thunder pushrods 7.400
gasket kit
thats about all you need to get it going.
I got the cam
comp 918's
gasket kit
Definately want to replace the Valvesprings, and go with TI retainers. May be worth while to replace the timing chain with a sturdier unit as well.
All you need:
Cam and springs
What you should get additionally:
gasket set, compressor tool, and maybe pushrods...
Unless you are running guideplates, you shouldn't need hardened pushrods. And Ti retainers are nice, but a waste if you aren't planning on seeing 6500+ rpms very often...
Cam and springs
I like what you say about TI being a waste. I have 918 springs and I am going to use the stock retainers. I am going to run a comp cams xe-r 224 561 112 lsa on a AA4. Yes I plan on getting my car tuned.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Biochem:
<strong> All you need:
Cam and springs
Unless you are running guideplates, you shouldn't need hardened pushrods. And Ti retainers are nice, but a waste if you aren't planning on seeing 6500+ rpms very often... </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Cam and springs
<strong>
Unless you are running guideplates, you shouldn't need hardened pushrods. And Ti retainers are nice, but a waste if you aren't planning on seeing 6500+ rpms very often... </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you are running the TR 224 cam then you should be seeing 6500. They lighten the valve train and they are on sale. So why not buy them? At least if you are running the 224 cam or larger.
<strong>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CRASH 02:
<strong> If you are running the TR 224 cam then you should be seeing 6500. They lighten the valve train and they are on sale. So why not buy them? At least if you are running the 224 cam or larger. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I could agree with that, but if you don't want to spend the $$$, you don't have to... unlike the springs themselves.
BTW- Spring compressor: http://www.mytoolstore.com/kd/kdengi13.html#3271
