STS turbo + boltons - what cam?
Old 12-24-2008, 01:37 PM
sujomatt's Avatar
Default STS turbo + boltons - what cam?
So as the title states - i am planning on a STS turbo kit, and i aleady have some bolt-ons. Just trying to plan out a cam to go with this setup.
The mods I will have are as follows:
STS Turbo kit
FAST 78MM intake manifold
42lb (or bigger) injectors
Bigger fuel pump
Pacesetter LTs
Pacesetter ORY
MAF Screen Removed
TB Bypass
Spec Stg3+ Clutch
A meth kit
And a cam that will b used with stock heads.
As you can tell im not looking for crazy power. I'd like to be around 500rwhp and torque similar. This is a weekend streetcar more or less
With that said - any suggestions on a decent Cam? or is a custom cam the only route?
Thanks!
Old 12-24-2008, 02:54 PM
LS1-NAVY's Avatar
well custom would be your best bet pm patrick g he will set u up
Old 12-24-2008, 03:01 PM
Super Speed's Avatar
From what I've read on here you don't want headers for the sts kit, so I'd just heat wrap your original manifolds, as to what cam, x2 for pming patrick!
Old 12-24-2008, 03:20 PM
sujomatt's Avatar
I was tempted to PM him. But before I do I was just curious what other peoples experience is.
I was thinking maybe an LS6 cam would do the trick from what ive been reading. But I'd love to have that cammed sound with that turbo.
I think i should have posted this in the forced induction area but im a noob lol
Old 12-25-2008, 01:07 AM
PREDATOR-Z's Avatar
224/224 .581/.581 112+2 LSA
That will do the trick nicely, it is a XE-R lobed cam (Comp Cam) 112 LSA and with 2* advance (110 ICL). 0 overlap so no boost lost, power everywhere across the band
Old 12-25-2008, 03:55 PM
TransAmcoupe98's Avatar
A more common cam to find that would be cheap and VERY effective would be an 02+Z06 cam out of a C5. They work well under boost. Guys sell there cams out of their Z's cheap after they do a cam swap.
Old 12-26-2008, 11:03 AM
JPH
JPH's Avatar
STS Turbo kit
Bigger fuel pump
Pacesetter LTs
Pacesetter ORY
MAF Screen Removed
TB Bypass
Spec Stg3+ Clutch
A meth kit
Thanks!
LS6 cam, LPE GT2-3, etc..
Old 12-26-2008, 01:41 PM
LS1 Tech Administrator
Patrick G's Avatar
Do a search on rear mount turbos running headers and larger turbo housings. You will see they suffer from dramatic turbo lag. While many people blame this on cam selection or turbo sizing, most of it has to do with heat/velocity of exhaust leading up to the rear-mount turbo. Long tube headers, while great for NA, absolutely murder the fast spooling ability of the larger turbos in back. Most find they can cure this by replacing the headers and y-pipe with the original stock exhaust manifolds and y-pipe. The performance improves even more if the y-pipe is wrapped with with header wrap all the way to the turbo housing.. When this is done, you can run a more aggressive cam with more duration and more overlap.
If you insist on running the less than optimal long tube headers with no heat wrap, then you'll have to run a cam with a small intake and exhaust duration and not very much overlap. Again, the exhaust setup you run is totally critical for optimum performance and should be dialed in before you select a cam.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 12-26-2008, 02:01 PM
tillery's Avatar
That is what I had been told before along time ago, that you need a certain amount of heat for a turbo. It helps with exhaust velocity. Thats why some xtreem stups use inconel for the manifolds-shortys- because you do lose alot of heat and velocity with headers. And with the turbo at the rear it needs a near stock size piping to achieve the velocity. But some of the big set ups Ive seen the turbo is installed very close to the manifold. Heat=energy=power. But to much=a lawn ornament.
Old 12-26-2008, 02:41 PM
mike13's Avatar
Is there a benefit from running a aftermarket Y pipe with the stock exhaust manifolds?
