hotchkis STB install
Old 12-24-2008, 03:05 PM
00HAWK#068's Avatar
Default hotchkis STB install
Just bought a new Hotchkis STB with no install instructions. Is it fairly easy to install? Should I be able to figure it out? I'm not real sure where the two I guess shims go? Any pics or help will be a great help. Thanks
Old 12-24-2008, 03:20 PM
nemss1's Avatar
ya its fairly easy man. the 2 shims go under the brackets for the shock towers. bolt down the brackets first, then the center bar
Old 12-24-2008, 03:47 PM
00HAWK#068's Avatar
Thats what I thought but was not sure , Thanks.
Old 12-24-2008, 07:16 PM
nemss1's Avatar
no prob man
Old 12-24-2008, 08:24 PM
Moderator
jimmyblue's Avatar
I never got any shims (bought used) and never even
noticed.
It will go easier if you disassemble, put the "feet" in
place with the nuts barely onto the studs and pilot
the cross-bolts in with a fat Phillips screwdriver and
then dog down the nuts.
The first time I put it on was some work, but the
car seems to have "taken a set" to it now.
