please help. crank wheel damaged.
Old 12-24-2008, 03:35 PM
TJ
TJ's Avatar
Default please help. crank wheel damaged.
somehow the wheel was damaged.
im going to put a cloth over the tab and pull it back strait with a pair of pliers then sand the burred edge off of the tab, unless someone else has a better suggestion.
is there ANY doubt at all to run this crank?
im not going through assembly and install with this piece if there isnt any certainty.
thanks.
Old 12-24-2008, 03:37 PM
2001z's Avatar
was that a new crank?
Old 12-24-2008, 05:02 PM
KCS
Moderator
KCS's Avatar
You're probably better off replacing that. The tolerance for play in the reluctor is only about .020", so if you feel you can get there, go for it.
Not to mention, whatever bent it may have knocked it off a degree or two in rotation.
Old 12-24-2008, 06:44 PM
TJ
TJ's Avatar
no. it was a used crank i purchased.
Old 12-24-2008, 06:45 PM
TJ
TJ's Avatar
can i send it to eagle to replace just the wheel? it appears to be made onto the crank?
Old 12-24-2008, 11:01 PM
djwimbo's Avatar
You should be fine trying to straighten it yourself. just be gentle.
Old 12-24-2008, 11:18 PM
TJ
TJ's Avatar
after review, the wheel has to be removeable. sending it off to eagle and having a new one pressed on. dont want to have any issues of it not firing, or mis firing.
Old 12-25-2008, 04:34 AM
the_merv's Avatar
That looks like one of the early Truck Cranks with the Spacer.
That can be straightened out, it does come off.
How did it get damaged?
Old 12-25-2008, 08:34 AM
TJ
TJ's Avatar
early trucks had a long crank without a spacer. later models required a spacer for the 4l80e to mate up.
i need the spacer to run my th350 with a small block converter.
it was damaged not by my doing. you live and learn.
Old 12-25-2008, 08:57 AM
the_merv's Avatar
^^Yea, true. I should have said Truck Spacer, not necessarily from an early model.
Old 12-25-2008, 12:55 PM
JFM-jr's Avatar
I read here the truck cranks are not gun drilled like the passenger car counterparts either. Can anybody confirm this?
