LT1 Nitrous Specific Cam Grind
Old 12-24-2008, 06:49 PM
BlownEarDrums's Avatar
Default LT1 Nitrous Specific Cam Grind
Curious about what cam/grind to get for a 300HP Direct port wet shot going on a forged, 360ci lt1 with full length headers, ported stock heads (exhaust ports worked also), and ported intake manifold...
I'm lost here all I could find is info on cams for small shots or N/A motors.
CCA-224-236-14 224 236 .503 .521 114??
Any help is appreciated
Old 12-26-2008, 09:33 AM
No one here running a nitrous specific cam on their LT1?
Old 12-26-2008, 03:07 PM
want297z's Avatar
Sure just not with a 300 shot. For something that big, I would suggest getting a custom cam and not one off of the shelf.
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
i have a cam for sale. it came out of my car last winter. i went 9.08 with it in the motor.
it is a large solid roller cam, only a few thousand miles on it. if interested pm me.
thanks
taner
Old 12-26-2008, 04:16 PM
Armyman2445's Avatar
I had one made for a 200shot, 355ci, LE2 heads M6 car, never used it though.
224/230 .582/.576 108LSA
Old 12-26-2008, 04:37 PM
ss.slp.ls1's Avatar
I think that for nitrous you want at least 4 degrees of split between the intake and exhaust. Like someone else mentioned, a custom grind would be your best bet, but a good off the self cam would be a CC503, 224/230 on a 112.
EDIT: The cam you specified seems like a good choice, it has a large split and it has a high exhaust lift.
Old 12-27-2008, 12:08 AM
OutlawZ's Avatar
PM me if you want cam specifics...... they are matched to my heads but you'll get the idea....
Old 12-27-2008, 12:41 AM
1997bird's Avatar
I had a hyd roller custom grind for a 355 with a 250-350 shot in mind, it's specs were 234/242 112+4.
Quick Reply: LT1 Nitrous Specific Cam Grind
