biggest tire you can fit in a 2000 trans am without tubing?
Old 12-24-2008, 07:21 PM
transamsam98's Avatar
Default biggest tire you can fit in a 2000 trans am without tubing?
I am hoping to put in a 325 mickey thompson drag radial on the back of my trans am or at least a 315. What needs to be done to fit it? O I am going to use a 15x 10 rim unsure of what brand / rim exactly yet however. I am open to suggestions.
Old 12-24-2008, 07:58 PM
1badzo's Avatar
I have seen the 325's on a buddys car he had to add the madman lower control arms, to get them to fit tho.
Old 12-24-2008, 08:15 PM
NOSJNKY's Avatar
325's here on 15x10.25" Bogarts with 5.5BS(rear narrowed 2.25 per side). I had the same setup with stock length rear and 15x10 Draglites with 7.5 BS. Roll the lips,grind a little, massage a little and voila!
Old 12-24-2008, 08:21 PM
hey nosjunky how it hold up on the strip with hard launches? also any chance you could post a pic from the rear with a lil bit better lighting?
Old 12-24-2008, 08:32 PM
NOSJNKY's Avatar
Zero problems, I have QA1's all the way around so the back doesnt move much, heres a couple of more pics.
Old 12-24-2008, 08:40 PM
man you have got me sold on these then man I am aiming for a 10 second 6 speed car so any help I can get trying to get my *** off the line I am gonna take. Did you just need to cut the lip on the fenders and remove the bump stop or what exactly did you need to do? I may swap my rear brakes for a set of v6 rear brakes or a set off an lt1 I am unsure at the moment beause I dont like the idea of grinding on them.
Old 12-24-2008, 08:42 PM
Also what did you do to sort out your suspension if you dont mind me asking
Old 12-24-2008, 08:47 PM
NOSJNKY's Avatar
Roll the fender lips(plenty of info on here for that) and i did remove the bump stops. I have single adjustable Qa1s all the way around, BMR extreme torque arm and Adj lower control arms,BMR sfc, LCA relocation brackets,BMR anti roll bar,stock v6 rear springs and 275lb coilovers up front. Also if you run Bogarts you wont have to grind. Good Luck.
Quick Reply: biggest tire you can fit in a 2000 trans am without tubing?
