need some help
Old 12-25-2008, 01:27 PM
19mike84's Avatar
Default need some help
ok so my door codes say my car came from the factory with 3.23's but i have a feeling the rear end is from a junk yard. is there anyway i can tell a 3 series between a 2 series by looking at the diff.?
Old 12-25-2008, 02:17 PM
jsteele90's Avatar
does your traction control and abs work?
Old 12-25-2008, 10:08 PM
19mike84's Avatar
abs doesnt work and i dont have trac cont
Old 12-26-2008, 12:23 AM
01ssreda4's Avatar
do a search for cruise speeds vs. gear vs. rpm. my 3.23 cruises in OD at 68 at 2K even with the 4L60e. or you could jack the car up and spin the driveshaft and tire and count the turns.
Old 12-26-2008, 12:54 AM
jsteele90's Avatar
sounds like a 2 series carrier then
Old 12-26-2008, 12:39 PM
19mike84's Avatar
yeah i was thinking it was a 2 series, it does have a spacer between the ring gear and the carier
Old 12-27-2008, 08:19 PM
19mike84's Avatar
change, it does not have a spacer behind the ring gear
