GM847 track times/dyno #s???
Old 12-26-2008, 04:11 PM
3rdgen92maro's Avatar
Default GM847 track times/dyno #s???
ok guys ive searched and searched for info on this cam and have come up with nothing really. i was wondering what everyone with this cam in a stock short block is running in the 1/4 and or dyno numbers. Everyone is pretty vague about it, most threads are its TO BIG dont run it itll destroy your bottom end spinning that much RPM. anyways any input would be great.
thanks
shawn
Old 12-26-2008, 04:38 PM
LSWHO's Avatar
From the extensive searching I've done the people who actually have done it like it a lot.
Most times are in the 11.8-12.4 range cam only stock bottom end.
WHP is in the 350 range cam only stock bottom end.
ALL of the dyno graphs I've seen with the stock bottom end and heads have a hp peak at 5800-6000.
I've compared them to dyno graphs of other cams and the 847 may not be as flat, but it is STILL higher across the board vs any non custom cam.
Clearly a custom cam will be better in most cases.
http://web.camaross.com/forums/showt...light=847+dyno
Old 12-26-2008, 04:40 PM
Razor_Blade's Avatar
Originally Posted by 3rdgen92maro
Everyone is pretty vague about it.
thanks
shawn
Agreed! Even those that like it never seem to produce any immpressive track times. I'm not interested in dyno numbers.
Old 12-26-2008, 04:42 PM
ss.slp.ls1's Avatar
Like you said, most threads that I have searched say that the GM847 is too large of a cam for a stock long block. I was going to get it, but after researching it, I opted for a CC503, I am happy with it, but I have no base of comparison against a GM847.
Old 12-26-2008, 04:46 PM
nevrlift13's Avatar
thanks
shawn
look up a board member KWIK96WS6 he ran that cam with ported heads and made like 400+ rwp i believe..
Taubr Unit's Avatar
ill let ya know come spring time, snow here now
Old 12-26-2008, 04:50 PM
ss.slp.ls1's Avatar
Ported heads vs. stock heads are a big difference.
Old 12-26-2008, 05:22 PM
same here man like 2ft atleast thanks for the input guys. so i can expect bottom 12s outta this cam before the heads get done? from what it looks like thats what everyone is running with it. Im shooting for 10s with ported heads and a 150 shot. think its possible?
Old 12-26-2008, 05:32 PM
96capricemgr's Avatar
So you found all the posts explaining why it is a poor choice for a stock shortblock but don't want that input??? You just want input telling you a bad idea is a good one???
You're going to fit in just fine.
Old 12-26-2008, 05:41 PM
your right ive found them and also seen that everyone who bashes the cam doesnt have any experience with and just say its a poor choice because thats what every other 847 hater says about it. ok sure you have to spin the hell out of it to make any power...i dont care ill spin 6700 out of it if it blows up so be it ill build another one.
Old 12-26-2008, 05:42 PM
its snowing like a **** here to...damn inland NW
Old 12-26-2008, 06:15 PM
Z-RATED94's Avatar
Sounds like you already made up your mind before you asked for opinions. Theres better cams out there that can make the same hp at a lower rpm, but if you prefer the 847, go for it.
Old 12-26-2008, 06:34 PM
MadMike 97 Z28's Avatar
hit the nail on the head everyone tells of how its too big for stock bottom end. not sure why everyone hates on it so much. pretty sure i heard the fastest cam only car is a gm847. I love my 847!!!
Old 12-26-2008, 07:27 PM
Old 12-26-2008, 07:38 PM
1996camaross's Avatar
i have the 292xfi cam which i belive its much bigger than the gm847 cam and i have no problem reving it up and getting all the pwer from it... its rpm range is from 2200 to 6200 and to top it off i have 1.6rr. i believe you will be fine with the gm847 cam.
Old 12-26-2008, 07:42 PM
BOLO's Avatar
I think the GM 847 cam is a great cam for the LT1. Especially in combination with set of ported heads and port matched intake. But then again, you can also get a custom grind close the to the same size as the 847 but with a tighter lsa. Just my opinion.
Old 12-26-2008, 07:58 PM
i pretty much have my mind made up im going to run the 847 with a set of hand ported heads and ported intake. hopefully itll go 11s on motor and 10s on bottle
Old 12-26-2008, 08:08 PM
BOLO's Avatar
Get a good tune and you'll get there.
Old 12-26-2008, 08:14 PM
we shall see as soon as the track opens up again...damn snow
Old 12-27-2008, 09:31 AM
engineermike's Avatar
I had the 847 in my old car and loved it. On a 383 with AFR210's it was good for 11.0's at 122+ mph.
But...
On stock or mild heads and stock or mild intake, it's no good. It tries to make power higher in the rpm range than the stock(ish) stuff can flow. If your goal is bottom 12's or even high 11's, you'd be better off with something smaller like the Crane 210/224.
Quick Reply: GM847 track times/dyno #s???
