Going under the knife tomorrow!!
Old 12-26-2008, 08:02 PM
JB_97ws6TA's Avatar
Default Going under the knife tomorrow!!
After a few months of research and parts gathering I am finally ready for the install. I am dropping the motor through the bottom but am still scratching my head on what would be best to set the k member on while I lift the car off of it. I will be using a lift so it should make life a little bit easier but I couldn't find a furniture dolly that looked stable enough to support that much weight. If anyone that has done this before has any suggestions I would appreciate it, and any last minute tips and things to look out for are welcomed. thanks guys
Old 12-26-2008, 09:24 PM
fergymoto's Avatar
I use a floor jack under the k member and a very light duty dolly under the tranny. It definitely isn't as convenient as a nice big heavy duty dolly to put under the whole thing but it works and I have never dropped it
Old 12-26-2008, 09:58 PM
ss.slp.ls1's Avatar
Harbor Freight sells dolly's that will support the k-member w/ engine and tranny.
Old 12-26-2008, 10:05 PM
JB_97ws6TA's Avatar
I wish there was a harbor freight nearby...closest one is 45 minutes away and I have to get started first thing in the morning unfortunately
Old 12-26-2008, 10:36 PM
ss.slp.ls1's Avatar
Well you'll be atleast a couple hours in by the time you need to support the engine, so you can take a break, get breakfast/lunch and buy a dolly.
It will be alot easier than using a jack.
Old 12-26-2008, 10:57 PM
shbox's Avatar
You just leave the wheels on it and put a jack under the trans and wheel it out. Pretty easy.
Old 12-26-2008, 11:04 PM
RoAdRaGe912's Avatar
Something like this??
Old 12-26-2008, 11:06 PM
ss.slp.ls1's Avatar
That looks pretty simple too.
Old 12-26-2008, 11:25 PM
fergymoto's Avatar
Yeah pretty much. My dolly is smaller and much lower to the ground. It is probably 24"x15" and 6" off the ground. I do it with no wheels on the k member though.
Old 12-27-2008, 08:21 PM
JB_97ws6TA's Avatar
well, I got the engine and trans out of it wasn't all that difficult but definately wasn't much fun! The place I am doing it at closed at 4 it took me 6 hours to drop the kmember and roll it out from underneath. I was under the assumption that it could be done much faster but checking and rechecking everything is time consuming. I have to wait until tuesday to tear back into it but I will keep everyone posted as it goes, I also took a TON of pictures mainly just so I could see how it goes back together if I have any questions but I will be more than happy to post the pics once it is complete or somewhere in between.
Old 12-28-2008, 03:26 PM
97LT1's Avatar
I would like to see your pics
Old 12-28-2008, 03:35 PM
ScrapSilicon's Avatar
2nded
Old 12-29-2008, 03:21 PM
1badzee's Avatar
I just drop it as is and lift/use the transmission as a lever to wheelbarrel the whole thing around.
