hp tuning
Old 12-26-2008, 09:27 PM
8urford2002's Avatar
Default hp tuning
Currently I have a 2002 camaro z28 a4 with pacesttter long tube headers,ORY,corsa exhaust, slp air lid,and 3.73 gears. I want to get my car tuned with hp tuners. What will expect to see/feel after i get this done.
Old 12-26-2008, 11:28 PM
Full-Force's Avatar
20hp +/-
Old 12-28-2008, 09:22 AM
TAQuickness's Avatar
I'd suspect the biggest diffence you will notice is your speedo and odometer will be correct after adjusting for the 3.73's. You should be able to find someone to update your gear setting and delete the rear O2's for <$100. The PCM can compensate for the rest of your mods.
Old 12-28-2008, 10:48 AM
1bad lad's Avatar
yyea right get it tuned you should see 20+/- hp at the wheels. oh yea put a cut out on the car it'll help pick up power over most mufflers. the only mufflers that i have seen that sit behind the axle that aren't a restriction is the slp kits and borla kits.
Old 12-28-2008, 10:31 PM
thanks for the input guys
