braided fuel lines for lt1
Old 12-27-2008, 05:01 PM
93TAJ.C.'s Avatar
Default braided fuel lines for lt1
Has anyone done a braided fuel line conversion? I really want to do it by cutting the fitting out of the back of the rails and have 6a's welded in. Has anyone done this? have any pics?
Old 12-27-2008, 05:02 PM
dsmawd350's Avatar
you dont need it till upwards of 550 rwhp i believe and do a search there are plenty of threads just like this
Old 12-27-2008, 05:07 PM
93TAJ.C.'s Avatar
I dont need it for power, i just want the ugly loom off the strut tower, Ill have the motor out soon and want to clean it up. And I have done research, I cant find much.
Old 12-27-2008, 05:29 PM
sn8ke eatr's Avatar
its somewhat straitfoward, tap the -6an fittings into the fuel rails, run a T fitting from the single main line to split into the new rails, also remember now you should get a quality fpr. this is what i plan to run:
stock tank, sump welded on
single main s.s line(unsure of size)
areomotive a1000 external fuel pump
areomotive adjustable fuel pressure regualtor
-6an return fuel line
and obviously the 2 -6an fittings into the back of each rail. and i want to run the main line into the engine compartment though the plate where my heater core used to be. basically out of sight.
hope that helps somewhat
Old 12-27-2008, 05:32 PM
LS1 SPEED's Avatar
you don't need to modify the rails for this
you need 4 quick connects to convert to AN
approx 12ft of line
4x #6 straight hose ends
remove the driver inner wheel well and drill a hole to route the lines through
see my car:
Old 12-27-2008, 05:46 PM
GIZMO's Avatar
I really believe that the fuel system is one item that really doesn't get enough attention. I run an 8 AN feed line on all of my Stockers and a 6 AN return. Even when I was running IHRA Pure Stock I found some gains in moving more volume than was needed. That also entails running a better fuel pump and a high quality regulator.
These are the fuel rails that I did for the kids "stock internals "car.
Old 12-27-2008, 05:49 PM
LS1 SPEED's Avatar
surprised
We have made 900+rwhp in turbo cars using the stock feed line with no issues.
Old 12-27-2008, 05:50 PM
GIZMO's Avatar
Originally Posted by LS1 SPEED
surprised
The fuel stays cooler in the rails.
Old 12-27-2008, 05:57 PM
93TAJ.C.'s Avatar
I guess I should have said that i have the 1993 lt1. So my fuel lines are connected beside the fuel rail right in the middle of the rail. And my crossover tube is behind the rails, not over the top towards the front like the 1994-1997
Old 12-27-2008, 06:11 PM
LS1 SPEED's Avatar
I have seen the 93 rails, but can't recall the connections.
if they are clip on then the quick connect fittings shown should still work, but you may need different ends
90, 45, etc
Old 12-27-2008, 06:13 PM
93TAJ.C.'s Avatar
Yes the quick connects still work. I want the fuel lines to come up behind the rails though. Do you know if anyone makes rails with 6an fitting on the back of the rail?
Old 12-27-2008, 06:25 PM
GIZMO's Avatar
Maybe Caprice will post up photos of the rails that I fixed for his 1993 intake? I use 1994-up rails and add an AN crossover.
Old 12-27-2008, 06:42 PM
LS1 SPEED's Avatar
I get ya...
as Gizmo noted go 94+ rails and if anyone in your area can weld it's not a big deal to convert the rails
Old 12-27-2008, 07:52 PM
93TAJ.C.'s Avatar
Wow i feel stupid lol, Thats a good idea gizmo
Old 12-27-2008, 08:47 PM
dsmawd350's Avatar
hes not gonna be able to go 94+ rails unless he gets rid of the crossover at the front! the 93 intake anifold doesnt have the line for the crossover to sit in
Old 12-27-2008, 08:53 PM
dsmawd350's Avatar
theres a pic of my old 93 manifold, as you can see 94+ fuel rails will not fit with their crossover at the front
Old 12-27-2008, 09:49 PM
93TAJ.C.'s Avatar
Yeah I actually misunderstood gizmo. I do know about the differences on the manifould though, and the rails. Thats why im really just going to end up cutting and welding at this point, anything to get rid of that ugly afterthought gm came up with. I mean, every other car has the lines up the firewall, why change it for the fbodys?
Oh and by the way dsmawd350, if your TA is a 1993 i have the same car as you, except mine is a t-56 ttop. But yours looks badass
Old 12-27-2008, 10:02 PM
dsmawd350's Avatar
thanks! its in the midst of a solid roller afr headed 383 fed by a big single turbo
Old 12-27-2008, 11:03 PM
GIZMO's Avatar
When you convert 1994+ rails to fit 1993 intakes you weld plugs where the crossover normally goes and build a new crossover using welded in AN fittings. I used to run the 1993 intakes on my Stock Eliminator motors until they corrected the spec. sheets, so I have done a few of these.
Old 12-28-2008, 08:13 AM
flyinZ's Avatar
Whats the reason, for the crossover?
Quick Reply: braided fuel lines for lt1
