v6 to v8
Old 12-27-2008, 10:26 PM
95firebird5.7's Avatar
Default v6 to v8
hello guys. well i bought a wrecked 97 t/a and im going to put the lt1 in my v6 firebird. i just want know if i will have to wire anything up if so what or will it all be plug and play since i have a donor. will i have to change the inside wire harness? also the car that the lt1 is going into is a 95 so its a ob1 will that be a problem? thanks guys.
Old 12-27-2008, 11:20 PM
ss.slp.ls1's Avatar
Where was the car wrecked? If it wasn't damaged in the front then you should be able to drop the whole k-member w/ engine, trans, computer, and wire harness and swap it into the v6 car. The OBD1/2 thing won't be an issue because you will be using the wire harness and computer from the donor car. The only thing that might present a problem is compatiablilty with the inside gauges and controls. I'm sure you can find a write up or a thread that will address any issues you may have. Good luck man.
Old 12-28-2008, 02:47 AM
the_merv's Avatar
You may have to move some wires around on the inside, but they should be all there.
With it being a 1995, it will have the OBDII Diagnostic Port, and the wiring was already inplace for mine as if it was an OBDII Car when I went through it to make sure everything was there for my swap.
Old 12-28-2008, 03:39 AM
DADDY&GIRL93TA's Avatar
What they said
Old 12-28-2008, 11:13 AM
in the back. one of the quater panel was ripped off and the side is all dented up and the passenger side door is caved in. i really wish i could fix it but i dont think i can be fixed
Old 12-28-2008, 12:24 PM
joelster's Avatar
Anything can be fixed. Just depends on how much you want to spend.
Quick Reply: v6 to v8
