MS4 graph inside
Old 12-28-2008, 02:08 PM
PONTIAC SLP's Avatar
Default MS4 graph inside
hi , here is my buddy car , 2002 FIREBIRD WS6 manual 6 speed , mods : MS4 112LSA , 4.10 Gears and full exhaust
Old 12-28-2008, 09:02 PM
RJB01camaross's Avatar
Nice numbers!!! With a Fast 90 and underdrive pulley, it should break 420
Old 12-28-2008, 09:04 PM
the highest number he pulled 409RWHP , but they tuned it to 403 because he want to spray a dry shoot 75HP
Old 12-28-2008, 09:16 PM
1bad lad's Avatar
not bad we had a 99 car same cam make 417 m6 10bolt with an ls6 intake
Old 12-29-2008, 03:54 PM
PewterScreaminMach's Avatar
Nice number.
Old 12-30-2008, 05:50 AM
98camaroLS1M6's Avatar
Nice results!!!
Old 01-05-2009, 06:06 PM
CavPat's Avatar
Wow. That's the final straw for me. I've been thinking seriously about getting this cam for my car but now it's set, I'm gettin it.
Old 01-05-2009, 08:04 PM
registered user
ScreaminRedZ's Avatar
Good numbers for the nitrous tune!
Old 01-06-2009, 06:21 AM
m1key99WS6's Avatar
With a dry kit you do not need to lower your base timing for a motor tune and a nitrous tune by the timing table. What I normally do with a dry kit car is run the max timing on motor and then use the Air inlet temperature tables to pull timing when the air inlet temp is -20 -50 degrees.
When the nitrous is sprayed the AIT will sense the drop in temperature and then pull timing by that method, thus giving you the best motor performance timing as well as the safety of pulling timing for the bottle.
I've done this on 5+ cars now without any problems.
Old 01-06-2009, 07:19 AM
cobrakiller221's Avatar
Nice numbers, but why is it only revving to 5400 rpm?
Old 01-06-2009, 07:24 AM
i don't know i think that who tuned my car as donkey lol , i think if i retune the car with revving to +6000RMP it will get new record !
Old 01-06-2009, 09:53 AM
Jedi Master
Gh0st's Avatar
That's the TIME, not the RPM
Old 01-06-2009, 11:44 AM
edcmat-l1's Avatar
I'd be interested in a complete graph. Torque, Power, engine speed, CF, smoothing.
Old 01-06-2009, 03:58 PM
BlkBird2000's Avatar
Were there any before numbers without the cam? I'm at 344/355.
Old 01-08-2009, 10:02 AM
My mistake, I didn't notice that it was time and not rpm's.
Old 01-08-2009, 10:27 AM
no , when i bought the car after 1 year i installed all mods then i tuned it one time and i rebuild the engine with some upgrades for juice
Old 01-08-2009, 10:34 AM
there are no TQ in the graph i don't know why ! but are u looking for those ?
CF: DIN Smoothing:5
RUN Type: RO Run Conditions: 91.87 degreeF, 29.73 in-Hg, Humidity: 16%, DIN: 1.03 . this is all
Old 01-08-2009, 04:35 PM
Kingc8r's Avatar
Not bad, the MS4 produces good number for sure. My buddies stalled auto made 401hp
