Finally ordered a converter :)
Well I finally made a decision on a converter and I am going with a Circle D converter. Members on this board are having real good results and I thought I would give them a shot. My tranny guy also gave them a great reference.
Looking forward to hitting the track in 2009
9's here we come
Marco
9's here we come
Marco
Good deal. I was going to go with circle D after doing a lot of research. People been getting great results as you said. Did you get the 5c ? My new 4600 should be here soon.
11.500s here we come.
Internet Mechanic
9's here we come
Marco
9's here we come
Marco
I am hoping for 11's with some work and a little personal weight reduction.
Race your car!
Good luck with it, the right converter will make a big difference. I picked up .4 and almost 5 mph from a converter swap, with pretty much no other changes.
You'll get a 9 second pass out of it this year for sure, the safety and all that stuff is the pita that will come after.
Internet Mechanic
Yea, the one thing I have always said is gears and converter / Launch RPM, is the most critical thing for a car that is for MAX effort 1/4mi or even a good street car. It is all about optimizing the set up the get the best out of it. Given the potential of the car, it should yeild great dividends, it just sucks when you crack the 9.99 Barrier, thats a whole nother level of safety equipment.
The only thing I need done for safety is a 10 pt cage, and that is getting done sometime next month
Then I'll make my license passes as soon we get the car working
Race your car!
circle d makes a very good converter, as does ati, ultimate converter concepts, and a few others.
I wouldn't put them in the same class as a bolt together chance converter, but I don't think ya need that until you're trying to go into the bottom 8 second range or faster.
Race your car!
That might be the case, I'm not sure.
I know that if you get an NHRA license, you can send the paperwork in, or a copy of your NHRA license and get an IHRA lic, but NHRA won't recognize an IHRA license and they will make you go thru it all again.
That being said, unless you don't plan on ever racing anywhere other then epping I'd get your NHRA one and then just send the paperwork in and get the IHRA one, be easier in the long run, that way in case you move someday and there's no IHRA track around, or if epping were to close or go to nhra, or if ya wanted to make a trip to another track you'd be good to go, stuff to think about. Same thing with the chassis cert, I'd get it NHRA certified.
Race your car!
Just something to think about, I'd get as much of the lic. stuff done and out ofo the way once and never have to do it again (just keep it up to date with your memberships and physcial's every year)
But I hear your reasoning as well and it also makes sense.... IMO, better to have then to not.
