pictures of my 5.3 powered notch
http://s276.photobucket.com/albums/kk3/brady346/
Just thought Id show a few pictures of my project. The pictures arent that great. Its just a budget build notch comprised of many cheap/used parts but also a few good parts. I really havent run into any problems or issues. Car is actually further along than these pictures show. The parts have all basically went right into place.
Here's the list of parts:
2005 5.3 liter
Thunder Racing Old Man Truck cam, patriot dual golds, comp pushrods
Edelbrock Vic Jr. carb intake
MSD 6LS controller
NX plate kit
Pacesetter truck shorties (no apparent clearance issues)
early 6.0 liter flywheel and spacer
TCI 5500 stall
locally built TH350
Ford 8.8 rearend
Maximum Motorsports full length SFC's
tubular upper and lower rear control arms
Competition Engineering 6 pt. weld in cage
AJE tubular K member for LS1
AJE tubular A arms
DRP coilover kit
quick steer manual rack (had to significantly lengthen steering shaft sent with this kit as shown by the pipe sleeve in the pics)
fuel cell feeding a holley blue
If anybody has any suggestions or constructive criticism let me know. Shooting to break into the 6's in the 1/8th on a pretty big hit of spray.
2005 5.3 liter
MSD 6LS controller
NX plate kit
TCI 5500 stall
locally built TH350
Ford 8.8 rearend
AJE tubular A arms
DRP coilover kit
Looks good, I'm building a twin Turbo 5.3 in a 92 Mustang GT.
https://ls1tech.com/forums/conversio...x-ls-swap.html
Thanks for all the compliments folks.
The most fun we have had with the whole project was putting an UNJETTED NOS nozzle on the stock 4 cylinder and putting the spray to it. It immediately slipped the tranny and hung out at max rpm with the spray still going. It finally popped after nearly a full ten lb. bottle went through it. Dang 4 banger really woke up with the sauce though. Melted the electrodes off of the plugs and filled the cylinders with liquid nitrous and blew a huge cloud of smoke/nitrous out from between the head and block. It was great.
looking good, i too am starting the swap, i have an aje tubular k for a 4.6 im going to use, and i have a local guy willing to sell me a 5.3 long block for 350 bucks, do you mind if in the future i ask questions if im stuck
