LS4 Performance - L92 heads
Ls4GXP
12-30-2008, 02:28 PM
Why wouldn't the L92 heads work in replacing our Ls6 heads? The GTO guys are replacing there Ls6 heads with the L92s, naturally they should just bolt in........no?
neilownz
12-30-2008, 02:55 PM
i think the intake runners might be different and we are kinda stuck with what we got for intake manifold.
Brian396
12-30-2008, 07:46 PM
Cylinder bore is too small on the ls4. And yea that intake.
07MCSS
12-31-2008, 07:36 PM
Our cars use the same 243 heads that were available on the LS6 and LS2 engines sans the hollow valves and stronger springs.
Ls4GXP
01-01-2009, 10:50 AM
So the L92s will easly bolt on in place but not give you any hp over the Ls6 because of the intake runners??
tokay57
01-01-2009, 11:16 AM
those heads are way to big for 325 cubic inches unless you want a pretty serious street/strip car, for which our cars does not have a stout platform for. you will need a minimum bore of 4 inches which the ls2 block has.
1BADCTS
Negative. The L92 heads require a minimum 4" cylinder bore diameter. Our LS4's only have 3.78". I'm not familiar enough with our motors yet to know if we could bore the LS4 to 4" or not.. but I doubt it! 0.22" is a lot of meat!
neilownz
01-01-2009, 02:26 PM
it would require resleeving or not using sleeves
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
