Best flowing catback?
Whats the best flowing catback on the market? I have a corsa catback setup right now and I've had magnaflow, slp loudmouth 1, and TSP true duals but they were too low. I was wondering if there was something out there that flowed better then what I have.
I've got my new pacesetter Y and TSP Rumbler for 250.00 right now. Pretty much about straight through. Matt at TSP told me the almost see no difference in hp between the True duals and the Rumbler.
what you have flows pretty well. compared to something like the LM or Rumbler you'd probably only see 1-2hp in all reality.
but the BEST flowing catback would be the 4" mufflex...assuming you put a good muffler on it. i think they come with flowmaster
My Borla flows rather well....I think they are all pretty close . Would be interesting to see if there is any difference between them when installed on the same car and run on a Dyno.
and darn $$$
"I think they are all pretty close . Would be interesting to see if there is any difference between them when installed on the same car and run on a Dyno"
agreed and AGREED!
figure the worst flowing catback is probably the flowmaster, and my guess would be you'd still see 10hp over stock. best (3" pipe) catback would be either the loudmouth or rumber, and figure those are good for 15hp.
so with the dozens of choices, and only a 5hp range, go with sound, look, and budget.
or better yet....go TDs
agreed and AGREED!
Also think of the weight, I have a mufflex 3.5 and the thing weight like 2x with my 2OTL weights. thouse things are heavy. Same with some true duels, some of you guys have 70-80#s systems
When I had h/c on my 346, it made 460/408 thu the SLP 20tl, and 466/410 with the 4inch Ipipe open at the end of the TA. Over the smooth blend to 3.5 over the rearend, then 3.25 into the mufflar.
^^^yeah catbacks with full size mufflers can get heavy. i can disconnect my 3 inch duals at the header and hold it and it seems about like thirty pounds but it doesn't even get to the end of the torque arm. the hooker mufflers themselves are supposed to flow really well. i saw a write up one time on flow cfm of mufflers and i believe it was in the top 3 in full sized mufflers.
