im stuck between choosing
What would be a more better choice a 93 or a 94 camaro. And by better i mean in terms of tuning,buying parts,maintenance,etc.Ive got 2 cars on the horizon of buying soon. There both automatics if that matters. My overall goal of the car is gonna be a street/strip car running in the low 11's/high 10's with most of the power coming from a procharger, proper camshaft and stall converter.Thanks
Do you have emissions in ur state? if so then i would say go with a 96-97 cause they are obdII and they just plug in at the emissions testing place.Also they have a better opti spark its vented and works better. But if thats not an issue i have heard the 93 has more problems then the 94. I have a 94 z28 with an auto. Hopefully more people can chime in with more facts.
94 ALL THE WAY. You can re-flash the computer for your tunes. The 93 requires a new chip to be burned every time. There are a few peculiarities of the 93 which are unique to that year, but the computer is THE BIGGIE.
I believe the main reason for the 93 being a hair faster (and I almost literally mean, by a hair) is a bit due to it's batch fire, simply because you are getting a bit more fuel. Which is why SFI in 94+ have a bit better economy. That and the M6's (although a bit weaker, or much weaker depending on what M6) had a much more aggressive gearing.
And while I love my 93, I will fully admit that had I known the difference in the years, I'd have gone with a 94. Yet after knowing now, 95 would be my choice since it's still OBD1 and has vented Opti.
no way man i wouldn't call u stupid, i use that smiley all the time. I havent found any 93's around me either. **** i cant even find an lt1.
