Valvesprings / pushrods
I am swapping a 02 ls1 / 4l80e setup into my 67 Camaro.
While I have the oil pan off I was going to go w/ ARP rod bolt kit.
As of now I am going to leave the stock cam / heads.
What valve spring and pushrods would be recommended for a 70/76mm turbo set up. 6-10psi
Also part numbers would help.
I would go with the Patriot Extreme springs. Exotic Performance Plus has a kit that includes,springs,tit retainers,seals,lockers for $275. Im switching from the patriot golds to the extremes. Push rods you can go a bunch of ways. I picked up some hardened stock length rods from Thunder racing like 3 years ago and 30k ago. They never really wear out and are cheap.
