Im curious to Find out what the gear ratio is in my car?
Old 12-31-2008, 12:28 AM
BlackDemonSS's Avatar
Default Im curious to Find out what the gear ratio is in my car?
I have a 99 SS camaro, with a manual six speed, is there any way i can run my vin number and find out what gear ration i have or is there a general setting?
Old 12-31-2008, 01:00 AM
nissan owner's Avatar
Here is some information from this thread
https://ls1tech.com/forums/gears-axl...ere-first.html
"Stock Gear Ratios:
M6: 3.42<----This should be you.
A4 Standard: 2.73 (GU2 code on the door sticker)
A4 Performance Axel: 3.23 (GU5 code on the door sticker)
WS6 and SS models came with 3.23s.
Your A4 did not come with 3.42s.
If your sticker is gone you tell which gears you have by your highway rpms:
3.23s @ 2000 rpm = 67 mph; 2.73s @ 2000 rpm = 80 mph
3.15s were available in A4 Vettes"
Old 12-31-2008, 01:32 AM
I ran my rpo codes on my car, and found out i have 3:42's
Old 12-31-2008, 05:30 AM
DiabloFormula's Avatar
Another way of doing it is to mark your tire and rotate it one full turn while counting how many times your driveshaft turns, i.e. 3 and 1/2 turns is 3.55, 4and 1/4 turns is 4.11 gears, etc.
Old 12-31-2008, 10:57 AM
km346's Avatar
This doesn't necessarily mean anything. you're car is an M6, as stated above that means no matter what it came from the factory with 3:42's. However if your not the first owner of the vehicle one of the previous owners could have changed the ring and pinion. I assume thats where DiabloFormula was going with his post.
If you are the original owner or know the gear ratio was never changed for a fact completely negate everything i just said.
Take care.
