crossover coolant tube on the back of the heads??
That tube is for the coolant (reversed cooled, cools the heads first instead of a traditional SBC) from each head connects to the single tube that goes up to the rad. You need to keep it. You could always go 6an with some fittings to make it look really nice.
Dont get rid of them.
Air or steam pockets have a hard time going down through the block to find their way out of the engine. Goofy the was gasses like to float on water.
The tube allows the air or steam an escape point up high.
You will find those who take the time to UNDERSTAND things often have very different opinions from the masses.
I am in the process of putting my car back together.... does it make any difference whether or not the crossover is on the front or back of the heads.... given these are aftermarket heads with machined threads on each end and this is far from a daily driver? - thanks
All of the heads are identical castings (symmetry wise). You can use a head on either side, the bolt holes are identical front and back, side and side. So while you technically could hook up some kind of tube in the front (which would require you to ditch the accessory bracket), I think the tube is on the back for a reason, the inlets from the pump is right at the front, so I don't think any hot spots would develop there. If someone insists on removing the steam pipe, at the VERY LEAST they should hook up a crossover tube connecting the two heads, but that wouldn't be much different than just leaving the tube there, but I guess you would have less clutter if you didn't see it.
unless you have deleted all the accessories on the front of the heads i dont think it would even fit. the "front" holes are plugged. just curious, why would you want it on the front anyway?
Because he stripped the holes out in the back. My opinion i would move it to there back. He is running a turbo lt1 so why chance the risk of hot spots or over heating on a project with so much effort and money into it. The way i understand it the air bubbles collect in that back of the heads and that's why its located there. JMO
