What suspension set up?!
Old 01-02-2009, 03:45 AM
Ironxcross's Avatar
Default What suspension set up?!
I'm thinking of replacing the worn out springs, shocks and struts in my car. My goal is to have something that rides smoother (takes bumps better) while still being decent for drag racing. Someone suggested getting new, factory springs and an adjustable shock/strut.
I could use some input here from you more experienced suspension guys.
The whole idea (since the car is a daily driver) is to make it smoother and more comfortable to drive, while having a set up that assists but is not fully dedicated to drag racing.
Ideas?
Old 01-02-2009, 07:52 AM
Foxxtron's Avatar
It's highly unlikely your springs are shot, but rather your shocks...
and that's where you should start.
Old 01-02-2009, 01:10 PM
01CaMMMaro's Avatar
wow its only the 2nd day of the new year and ive seen 3 posts reguarding shocks already... anyways, koni's seem to be the only shocks that are good for comfort and drag... really hard to mix those together though imo.
Old 01-02-2009, 01:30 PM
Ironxcross's Avatar
the car does have 101k on it
Old 01-02-2009, 11:08 PM
Ironxcross's Avatar
I found some KYB AGX adjustable shocks. Would they work for my stock size springs?
Old 01-02-2009, 11:56 PM
Ironxcross's Avatar
what about strange SA's?
Old 01-03-2009, 07:38 AM
Foxxtron's Avatar
Whilst that is true, I've seen cars with their original springs with over 150K (even 200K) on them being driven on some pretty rough roads. With the exception of some free spring height lost, their spring rates are retained.
I still say with what you've proposed...it's best to start with shocks and see how it goes from there.
Old 01-03-2009, 01:35 PM
Ironxcross's Avatar
Thanks for the input!
I was thinking about the KYB AGX shocks. Would they be good for stock size springs?
Old 01-04-2009, 06:09 AM
Foxxtron's Avatar
They shall fit the stock springs (provided they're not cut). AFA what you're going to do with shocks, you may want to research other options as well, at least to make sure what you're expecting for ride vs. performance.
Old 01-04-2009, 05:47 PM
Casper9T9's Avatar
Bilstein HDs are a good match for the stock springs.
Old 01-04-2009, 08:19 PM
Pontiacerator
RevGTO's Avatar
Second that. If you're not planning to lower the car, want a nice comfortable ride, decent handling, and good weight transfer at the track, Bilsteins are the way to go. Keep your stock springs and contact Sam Strano for his Bilstein set-up.
Old 01-04-2009, 11:00 PM
Ironxcross's Avatar
I had the bilstein hds, and they really weren't for me. They rode kinda rough.
Old 01-05-2009, 09:47 PM
Pontiacerator
RevGTO's Avatar
Wow. First time I've heard that. But if you had the current spec rears, I can see how. Too much compression, not enough rebound. That's why Sam's set-up is the way to go with Bilsteins.
I replaced my front Bilsteins with Koni's on the lower perch. Now THAT made for a rough ride. I thought the Bilsteins were comfy.
Old 01-06-2009, 10:31 AM
LS1TECH Sponsor
Sam Strano's Avatar
Welcome to the world where not is all it seems.
The above few posts illustrates perfectly why I do my level best to talk to all my customers instead of relying on e-mail and internet opinion. Everyone is different and has a different take on any possible thing you could discuss.
While it's rare to hear of someone thinking Bilstein's are too hard, it happens. There are also those that feel they lack damping, and others feel they are perfect, and everything in between. What's more is RevGTO has a similar thing happen to him with his Koni's and with his wants. While firm, it's not common for many to consider them to rough especially if the settings aren't sky-high (and his aren't from what I remember). Meanwhile Rev is surprised that Ironxcross didn't love the Bilstein's.... See what I mean?
It's also worth noting that not all Bilstein's are the same. In fact there are two very different valvings of "Bilstein HD" out there for this car. Add those to the SLP's, and the Revalves I used to do, and the Strano Spec setup (not revalved in the front, but an alternate rear production valving not the current messed up psuedo deCarbon rears everyone else sells) and saying "I had Bilstein's" is about like telling someone you drive a GM car, but that's all you say. Camaro, Firebird, Chevette, Corvette?????
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 01-06-2009, 03:44 PM
jmilz28's Avatar
Call Sam and talk to him, follow his advice.
FWIW, my Bilsteins were a huge improvement but I wish I had gone Konis on my daily driver.
Old 01-06-2009, 04:23 PM
JD_AMG's Avatar
Were you on stock springs? Did you change anything else when you installed the bilsteins?
Old 01-10-2009, 10:28 PM
Ironxcross's Avatar
nope, not at all. would that have been the problem?
Quick Reply: What suspension set up?!
