8ga power and ground for fuel pump too much?
I have some 8 ga nice amp wire that just happens to be of use to me for wiring up my a1000 perhaps.
Is this too much when wired with a 30amp relay, or will it work fine?
Any help is appreciated. Just figured id use it since i have it.. Not skimp out on some radio shack 12 ga or somethin..
thanks!
thanks!
just what i wanted to hear.. the prob is def the connectors i agree.. i need to find female spade style ones for 8ga to plug into the relay which may be tough.. And each one of those ******* noids me out cause if it comes loose, im history.
i bet you i checked the terminals 20 times just on the two for the pump.. tuggin on em makin sure..
thanks for the advice man!
