Started the Underhood cleanup..........
Old 01-02-2009, 02:05 PM
Huggerorange73's Avatar
Default COMPLETED the Underhood cleanup, finally!!!!!
Winter is pretty long & boring in Chicago, and with Silver Ghost's kick *** deal on powder coating I tore into the engine for a little clean up.....
Once I get all the parts back I'll be sure to follow up in this thread....
Old 01-02-2009, 02:26 PM
01CaMMMaro's Avatar
sweet... you should take a hold of the hood latch and wire mod while your waiting on your parts to come in!
Old 01-02-2009, 02:41 PM
motoo344's Avatar
Nice, I have been doing the same. Waiting for my parts from Sean and the coolant lines and the ls6 pcv system.
Old 01-02-2009, 05:57 PM
smg267's Avatar
perfect time to swap in the LS6 valley cover!!
Old 01-02-2009, 06:08 PM
02gtp4now's Avatar
cool like stated do the wire and hood latch mods, also what color are you going with.
Old 01-02-2009, 07:26 PM
FamousZ's Avatar
Looks good!! Cant wait to see it done...
Old 01-02-2009, 08:45 PM
TORCHD 02 TA's Avatar
Like others have said, do the !wiremod....
Your ports where the intake sits look clean. No carbon build up
next up my car
Old 01-02-2009, 09:08 PM
Thanks guys......
The MAF is going to be orange, throttle body black, LS6 intake manifold orange.
Valve covers black, coil brackets orange.
Should look pretty sweet once it's all in one piece again...
Old 01-02-2009, 09:20 PM
MEZA TA's Avatar
throw in a battery cover to match.
Old 01-03-2009, 12:22 AM
pwterz28's Avatar
should look bad ***
Old 01-03-2009, 12:35 AM
hlaalu's Avatar
this thread was a big **** tease what colors are you going with everything?
Old 01-03-2009, 10:47 AM
I do need to ditch the fugly green battery in the spring....it goes with nothing under the hood
As far as what's going to be what color.....The MAF is going to be orange, throttle body black, LS6 intake manifold orange.
Old 01-03-2009, 10:52 AM
2000_SS's Avatar
that's gonna look good for sure. you should do the wire mod and EVAP relocation too...and maybe get a PCM cover...if you can.
Old 01-03-2009, 01:58 PM
litemup02's Avatar
Sweet...looks identical to mine right now Silverghost also has my parts. Intake, GMPP valve covers, T/B, MAF and pulleys
Old 01-03-2009, 03:13 PM
Breathtaker's Avatar
That's what I was gonna say...that battery...
Old 01-03-2009, 05:55 PM
hlaalu's Avatar
nice thats kind of what i plan on doing with mine, only orange = pewter
Old 02-10-2009, 11:22 PM
Over the last month, I've been doing a few things.....I went with the LS6 valley cover, and had Sean over at Powder Pro work his magic on my stuff.....here's another little teaser on where I'm at due to Chicago's mini spring we just had!
Old 02-10-2009, 11:23 PM
what are you keeping over you valve covers to prevent dirt getting in there
Old 02-10-2009, 11:26 PM
When I wasn't out there wrenching....I had my LS1 all snuggled up in blankets so it would't get cold or dirty!
Old 02-10-2009, 11:34 PM
ok so you jsut close the hood, you did not put rags over it or anything?
Quick Reply: Started the Underhood cleanup..........
