REAR End question
Old 01-02-2009, 08:27 PM
gc302047's Avatar
Default REAR End question
what does 4 channel and 3 channel mean? did they come on certain cars? the reason im asking is because im buying a 10 bold rear end and wondering if it mattered
Please explain to me
any info is good
thanks
Old 01-02-2009, 09:16 PM
HavATampa's Avatar
It does matter. A 3 channel rearend is setup just for ABS (Anti-Lock Brakes). It's easy to tell a 3 channel because the ABS sensor is sitting on top of the pumpkin and is reading a toothed ring attached to the ring gear. A 4 channel rear includes ABS and TCS (Traction Control). There is a sensor at each end of the axles (but not on top of the pumpkin) and a toothed ring is pressed on next to the bearings of each axle for the sensor to read. If your car came with TCS, you should find a rearend that has the 4 channel setup so your cars computer doesnt freak out.
Old 01-02-2009, 09:20 PM
HavATampa's Avatar
Oh yeah, please read the Rearend FAQ stickies https://ls1tech.com/forums/showthrea...ferrerid=13535 at the top of this forum. A lot of good info in those things. See #15 and #16 for your answers too.
