Spring cups for Strange??
Old 01-02-2009, 08:30 PM
BassProCamaro97's Avatar
Default Spring cups for Strange??
do I need to use diffrent spring cups for Strange front shocks or can I use the stock ones?
I did search and couldn't come up with anything for strange shocks.
Thanks,
~Jim~
Old 01-03-2009, 09:30 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
the Strange front shocks come with a lower spring seat for the the standard 2.5 inch i.d. coil-over springs. you can use the stock upper mount if you use the Strange SPC300 springs or the QA1 springs for stock upper mount. otherwise the Strange shocks are available to be used with a standard 2.5 inch i.d. coil-over spring.
Old 01-03-2009, 10:02 AM
Thanks for the info Thats what I needed to know.
I'm using the SPC300 so Ishouldn't have a problem.
~Jim~
Old 01-03-2009, 12:40 PM
BadBandit69's Avatar
you can get lower spring cups to fit a full sized stock spring for extra $ if you want. But otherwise if your going with the smaller coil designed for those shocks they will come with what is needed to do the job. btw i would go with at least a 16" long spring. I've got 14" on my car and they work but i had to adjust them to the top to get a decent ride height out of them.
