Fast 101
1 Post
I was reading about a 102mm FAST setup (intake/tb) that was going to be for the ls3 and l92 setups. I guwss that means it won't work on our ls1's and ls2's
What I couldn't find out was whether or not the internals were differnt or if it was like the 92, only a bigger inlet vs all new design.
Anyone know ?? Vengeance has it on there website COMING SOON
1 Post
How about the intake itself, is it different from the 92 internally, or is just a larger inlet with exactly the same internals? 90 mm FAST and 92 mm FAST are the same with the only difference being the inlet. How about the 102 ?? I really hope that FAST did something to make it better and not just provide a larger inlet.
From what I have seen the 102 is internally different. It has a modular runner design instead of the runners being all on the same piece molded together. And if I recall correctly they were talking about being able to swap the runners out for different applications. There was a video posted in the EXTERNAL ENGINE section.
LS1Tech Premium Sponsor
^^ From all we've seen that is correct. There will at some point be available other runners so you can swap for specific applications. At PRI Comp/FAST were saying about April for the ETA.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Found some pics and a pdf that show the new design:
https://ls1tech.com/forums/generatio...eads-sema.html
http://www.fuelairspark.com/WhatsNew...kemanifold.pdf
