Victor jr efi fuel line question?
Basically im trying to figure out what size fuel line you guys are using? The problem im having is the quick disconnect (640850) is 3/8 to -6an male and i was planning on running -8an line and we were trying to find a adapter fitting from -6an female to -8an male. Or could I just run -6an all the way through it?
Thanks
Darren
Thanks
Darren
You can use an Aeromotive 15118 adapter to go from 3/8" quick connect to AN #8
Like this:
http://www.aeromotiveinc.com/products.php?prod=87
15118 3/8" Female Quick Connect / AN-08 Port
Then all you need is a #8 male to <insert fitting type> depending on how your connecting the AN line to the adapter.
Like this for example:
or like this to adapt from AN line to the 15118
Like this:
