my Project
my Project
I have chevy corvette and my car is weekend use
I have some stuffs:LS7 Crank
LS7 Connecting rods
LS7 Intake Manifold
LS7 heads
6.0L Iron Block
I am planing to put LS7 crank shafts and LS7 Connecting rods in 6.0 Iron Block can I do that ?? and what type of pistons do you suggest guys to go with???
I want the pistons for nitrous
Is it important to balance the engine ???
Is there will be problem in high RPM ???
LS7 Connecting rods
LS7 Intake Manifold
LS7 heads
6.0L Iron Block
thank you tiresmo0ke for your post
and i mean in high rpm is the engine will work ok ???
the engin will be gen 3 iron block 6.0
I am ask if I put the LS7 Connecting rods and the ls7 crank in the gen3 iron block can I do that ??? and the piston is 4.030
The iron block is a gen 3 your crank is a gen 4 with a 58x reluctor wheel. I dont think it will work. I dont know much about the LS7 but im pretty sure its pistons, crank and rods are going to need an ls7 block to function.
You have to change the reluctor wheel to a 24 tooth in order for it to work with your ECU. The LS7 crank isnt anything special. It does have a longer snout and that will need to be milled down. If I were you I would just use an aftermarket crank, LS7 rods and pistons to whatever bore you specify.
