Suggest 403 cam for odd application
I have searched and read ALL of the 402/403 threads and no one's combination of hardware and personal requirements exactly match mine, so I will ask everyone for their opinion. (I have gotten recommendations from Patrick G and Predator-Z directly). I plan to speak with Tony Mamo on Monday. I will then try to average out all the responses and make a final decision.
My requirements are for a nice, strong daily driver. No racing of any kind. I want an 800 rpm idle, perfect off-idle response, and the ability to pull cleanly from 1000rpm in sixth gear. Needs to be able to slog along in stop and roll traffic for days on end. I am willing to leave power on the table for good manners, so please be conservative with your recommendations.
403 short block from Lingenfelter, with GT-11 cam (215/231/118 lsa). Much too small for a 403 in my opinion, but it is what they recommended.
10.5:1 compression. I didn't want gas problems, and tried to leave a little room for a Maggie if I ever win the lottery.
Ported stage 2 243 heads from Patriot (2.02/1.57 - 305 cfm intake/227 cfm exhaust @.600) 64cc chambers.
Stock LS-6 intake
Stock LS-1 throttle body (78mm?)
T-56 with 3.73 rear gear. I'll guess 3500 pound car.
1.75" headers, 2.5" exhaust
LS-7 clutch
Currently at 405rwhp/415rwtq. I am certain there is more to be had while keeping the street manners that I desire.
Thanks in advance for your recommendations.
Mark
Stock LS-6 intake
LS-7 clutch
Mark
Stock LS-6 intake
LS-7 clutch
Mark
Stock LS-6 intake
LS-7 clutch
Mark
FWIW, I am always surprised that folks who supply ported heads don't offer the best cams to go with their heads and various engine combos. They should know how their heads make power on dynos, not just their flowbench numbers. Some folks only sell a package of heads and the appropriate cam for the application.
As you have found in your searching, there are 402 combos that drive just as you want but make another hundred ponies and 75-80 more max torque than what you have. The head/manifold/cam/tune are responsible, of course, and would be expensive for you to duplicate.
I suggest you look farther than you have or at the very least pick one cam guy and go with his recommendation.
Jon
ditch the LS6 intake and throttle body and go with a ported fast 92/92 combo. This won't affect driveability and should wake it up nicely. You will get way more power out of this mod than changing the cam if driveability is your primary concern.
A 232/236 114+2 is what I ran in my old 383. It made 489 rwhp and had pretty good street manners.
If you have a good local tuner it should meet all of your needs. Keep in mind that your engine is just a big air pump. Your LS6 intake and 78MM TB is a huge restriction that you are trying to overcome with a larger cam.
232/238 .600/.615 113+2
....but i don't know anything about cams
So - if you don't know anything about cams why are you making a suggestion?
Or - do you know something about cams? What are your credentials?
Pay Patrick G his cam fee and be done with it, do it once, do it right. if you had a cookie-cutter engine in your car, you could safely copy an existing cam posted on here, but since you have a unique setup with unique intentions, you need professional help, not people like me pulling random cam specs out of thin air. what i said may have been spot on, but i'm guessing way off. either way, there is now something to discuss.
XER lobes 238/244 .605/.615 112º+2º
speed inc. SS1 cam
http://www.speedinc.com/cont.cfm?cid=C0000150
speed inc. SS1 cam
