Header write up?
Header write up?
Does anyone have one? I'm thnkng about getting pace setters for my trans am and not sure weather i should spend the money on the headers or do a ory. want to see all the work. I thought there was a manual with the pace setters but i cant find it
it is pretty cut and dry... remove alternator and air lines just for some extra room, pull spark plugs and steering shaft, don't forget the egr on the passengers side rear, dipstick has to get out of the way passenger side goes in from the bottom, drivers side goes in through the top, be carefull with pacesetter's exhaust gasket kind of low quality in my opinion, change the plugs while you have headers suspended in place but not bolted down, don't crack any spark plugs and double check your spark plug wire routing. If you are using P/S headers, you have to get the P/S y-pipe.
the spark plugs are 5/8" right, i bought a socket for it then saw they make both sizes. The car doesn't have anywhere near the mileage to need plugs but i planned on changeing them anyways..
Before you consider doing headers or ORY, you may want to find out about ORYs, cause they aren't common without headers... cause to me it sounds like your gonna want both.
for header install tech help look here: I am not sure how many of those links include header install tech, but I know some do. There are plenty more out there too. I found you a bunch though. Good luck and God bless.
http://lt1howto.com/articles/flpinstall.htm
http://www.97ta.com/flp_header.shtml
http://www.createforum.com/fbodyinstall/
http://shbox.com/page/index.html
http://www.bfranker.badz28.com/
http://www.go-fast.org/z28
http://www.installuniversity.com/ins...sity/index.htm
http://www.ssz28.com/tech/
http://www.fbody.com
another guy just asked this.
