Which white wire is for tach on WS6?
Re: Where is the pcm located?
If their POS site is working you can try here. http://www.ls1.com/00pinpcm.htm
The green wire is hooked up to #10 wire. I have sucesfully installed one in my 00SS and it works flawless. We took power for the tack from the fuse panel on the side of the driver door
I found the problem, you have to set the tach (autometer) for four cylinder operation, because of the five square volt output. The second tech I talked to autometer new his stuff.
