AFR Heads?
Old 10-01-2003, 01:07 PM
Back in the staging lane
Beeler422's Avatar
Default AFR Heads?
I've been hearing bits and pieces about these heads. Does anyone have any information on them? I know nothing about them. Thanks.
Old 10-01-2003, 01:12 PM
HumpinSS's Avatar
Default Re: AFR Heads?
https://ls1tech.com/threads/showflat...=7&fpart=1
Old 10-01-2003, 01:27 PM
robertbartsch's Avatar
...the guy from AFR described the heads a few days ago here in a post...release is in February 04, i think...
the heads are not GM castings and apparently they flow a TON! Unfortunately, they will be pricy!
Old 10-01-2003, 01:40 PM
30th TA 0219's Avatar
pricy? Considering how much GTP and MTI heads are (esp GTP) they will not be bad. Plus, if what he says is true about the ports, there will be so much more to the story than flow and PEAK dyno numbers. I can't wait to see the area unser the curve with these sum'bitches!
Old 10-01-2003, 10:17 PM
SStrokerAce's Avatar
I'm excited too. Next month I'm going to throw down a deposit on a set of cores so I can have them worked. If anyone is interested get ahold of me, we can do two sets. FWIW I have a dealer relationship with AFR so I can't go below a certain point on the castings but I can give you a deal.
Bret
Old 10-01-2003, 10:28 PM
John's vette's Avatar
Reading this gets me VERY excited.
Tony's latest comments on Corvette Forum
Old 10-02-2003, 01:16 AM
CNB
CNB's Avatar
SStrokerAce, count me in for the 200cc.
