tech 2
Re: tech 2
you can reflash the pcm back to the stock tune for that vin number with it...had to have mine done. and i think you can also adjust the mileage on the odometer as well.
not sure what else, those are the 2 things that stick out in my mind
Re: tech 2
GM dealerships can use it to reprogram a pcm but only back to stock for that vehicle's VIN. To my knowledge your mileage is not stored in the PCM and is NOT changeable via the Tech2.
Re: tech 2
Do you know at what or what is fuel trim or what should it be at to get more power also the spark timing what should it be at and where should it work better?
Re: tech 2
I HIGHLY doubt that whoever changed their mileage did it with a Tech 2. It's just a scan tool used to monitor and recorded. Dealers upload the info and it goes back into GM for analysis fun.
But changing mileage, that requires more than a scan tool. You wouldn't be thinking of doing something illegal would you?
Right on about how you can change things w/ a tech 2 but as soon as you unplug it, there goes the changes.
Get a laptop to tweek your sensors if that's what your after.
Re: tech 2
It is really only a diagnostic or scan tool.
Any changes made with it (which it can only do a few) go away as sooon as you remove the tool from the car.
