Turbo Feed Line....
Old 01-05-2009, 03:29 AM
INCOGNITO-TA's Avatar
Lightbulb Turbo Feed Line....
I am curious as to what size feed line I should be running on my S91 turbo. It's obviously not a BB turbo so it's going to need more pressure and oil getting through there. But is -4 going to be just fine without a chance of having any problems or do I need to step up to a -6? The car has not been fired yet and I do not want any problems with that new turbo sitting on there. Your help and suggestions would be greatly appreciated.
BTW. I have done a search here on ls1tech for this and have came up with nothing other then if you have a BB turbo... Thanks again!
Old 01-05-2009, 07:15 AM
Fireball's Avatar
I run a -4 with my FI-98X turbo. No issues whatsoever. Run a big drain line though. I run a -12
Old 01-05-2009, 09:22 AM
veee8's Avatar
^^^^^^Same here....
Old 01-05-2009, 09:45 AM
y2khawk's Avatar
we tend to start with -4 and restrict down from there if needed.
Old 01-05-2009, 03:06 PM
Thanks for the info guys! It's much appreciated!
Old 01-05-2009, 03:41 PM
veee8's Avatar
I double checked, mine is a -3 feed, -12 return.
Old 01-05-2009, 04:57 PM
ModularTurbo's Avatar
Oil feed and drain kits available if anyone needs help
Quick Reply: Turbo Feed Line....
