low oil pressure at idle
I bought a 6.0 2500 farm truck real cheap. Shortly after startup when the fast idle kicks off the trucks oil pressure will drop to zero and the dummy light flashes. As long as I barely bump the gas or keep the idle over 550rpm its over 25/30psi. I figured the farm use clumped up the oil with short trips never fully heating up the entire oil, so I flushed it onced with the engine flush which seemed to help alittle.
It looks like droping the oil pan to clean it out includes dropping the front diff so that last resort.
I've heard some old timers talk about draining half the oil, filling with diseal to flush the sludge out. Are there safe options without hurting seals and bearings or what?
If I were you, I would check the actual oil pressure with a good known pressure gauge before you start trying anything else. If that checks out, then I would probably start with the sender which could be partly plugged or just junk.
Similar to what mine was doing. I just pulled my engine and found sludge and dried, flaky oil EVERWHERE. There was only about 3 or 4mm in the oil pickup screen where oil could actually get through.
Might try using Trans. fluid to flush it out. Replace 1 quart of oil with 1 quart of trans. fluid.
LSxGuy widda 9sec Mustang
If its sludge it'll probably take pulling the pan off to clear it all out, but might be able to be bandaided if its not too bad. I would also recommend replacing the oil pump and pickup tube o-ring. At least with the pump off and oil pan loose you can use compressed air to blow through the pickup tube and attempt to clean it out.
Do the lifters ever get noisy from lack of oil?
i don't think there is anything wrong with your motor, if it is ldling that low and stalls every now and then. there is a software update to fix that. i would do the update before going any further.
