headers install
Old 01-05-2009, 02:20 PM
6spdscreaminchickin's Avatar
Default headers install
is a 02 sencer extention absolutely needed for long tube install?
Old 01-05-2009, 02:21 PM
RamAir95TA's Avatar
You will need at least one. With my Hookers, I needed one.
What headers are you installing?
Old 01-05-2009, 02:24 PM
pacesetter long tubes, pacesetter y-pipe, to a flowmaster. (flowmaster came on car)
Old 01-05-2009, 02:57 PM
also my headers only have one hole in them(for the 02 sencer) what am i soposed to do with the e.g.r. and a.i.r.?
Old 01-05-2009, 03:00 PM
RamAir95TA's Avatar
Sounds like you have non-emissions Pacesetters. You'll need block-off plates for the EGR and you'll need to delete the AIR pump. If you do a search you'll find a ton of info on both. Removing the AIR pump is easy, just a few bolts, hoses, and pipes.
Old 01-05-2009, 04:06 PM
alright but i still dont know if i need one, two, or no 02 sencer extentions.
Old 01-05-2009, 04:31 PM
Elliott's94Z's Avatar
I would rec running them. With my off road headers and y-pipe I'm running (2) o2's with 12 inch extensions. Summit sells the o2 extensions..
Old 01-05-2009, 04:35 PM
PNYKLR-TA's Avatar
yea 2 12" extensions should be fine.
Old 01-05-2009, 09:16 PM
blk97z28's Avatar
https://ls1tech.com/forums/lt1-lt4-m...o-numbers.html
This is my thread with all complete pics on installing headers hope this helps
Old 01-06-2009, 02:07 PM
ed's-byrd's Avatar
Caspers electronics sells them as well.
