procharger SC
Old 01-05-2009, 06:34 PM
BOTTLE ROCKET's Avatar
Default procharger SC
Are there any negative issues with procharger SCs? It seems like All of the big name's (ECS, A &A, etc) are running paxton, vortec etc. How are prochargers on C5s?
Thanks
Old 01-05-2009, 06:39 PM
Floader's Avatar
its not the head units, it the brackets. I think A&A used to use ProChargers, but got in a tiff over the brackets. Do a search for C5 stuff, its out there
Old 01-05-2009, 09:01 PM
LS1Tech Sponsor
Slowhawk's Avatar
I still prefer the Prochargers over the other 2.We've done a ton of C5's with them.
Old 01-05-2009, 11:35 PM
Customizing Director
MadIceV8's Avatar
Prochargers are very reliable and proven. No reason to not consider them.
Old 01-06-2009, 04:53 AM
I have a H/C car with ALL the bolt ons, making 414 rwhp with TC unlocked. I guess I was wondering if adding the P1SC-1 would be a good fit. I have a 224 cams with Dart heads at 10.8, and I don't want to swap out heads. I would like to see around 550rwhp at around 6psi, but didn't know how well my trans or stock bottom end would handle it. I NEVER go to the track anymore, so it is just a street setup.
Old 01-06-2009, 07:42 AM
Floader's Avatar
I made 566rwhp on a cam only motor at 8-9lbs. Just get a good tuner like Slowhawk any youll be just fine.
Old 01-06-2009, 08:00 AM
kcmags's Avatar
It will make 550 easy & be very drivable with a good tune. I made those numbers with a 01 ls6....Made hundreds of passes..high 10's...& drove 20,000 + miles & never had a valve cover off. That was with a 01 ZO6
Old 01-06-2009, 08:53 AM
AFASTYZFR1's Avatar
Love my procharger.....never missed a beat
Old 01-07-2009, 05:31 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...Car.php?car=54
Check out the build using an ATI ProCharger D-1SC on the above C5. Bob
Old 01-07-2009, 07:02 AM
Awake455's Avatar
Bob, I always truly enjoy going through your builds. You guys do awesome work, and someone there knows how to run the camera nicely. I show your builds off every chance I get to fellow military type folk.
Old 01-07-2009, 07:22 AM
EPP
EPP's Avatar
Thumbs up
Thanks, we appreciate it. I do the camera and website stuff myself. I use to be in charge of a group of guys in an engineering department in a former life, where we took pic's and created installation manuals, and I enjoy doing the website stuff. Bob
Old 01-07-2009, 11:47 AM
9t8z28's Avatar
Originally Posted by awake455
bob, i always truly enjoy going through your builds. You guys do awesome work, and someone there knows how to run the camera nicely.
x2!!!!
Old 01-08-2009, 04:40 AM
EPP
EPP's Avatar
Thumbs up
Originally Posted by 9t8z28
x2!!!!
Thanks, we appreciate it! Bob
Old 01-08-2009, 05:21 AM
cws T/A's Avatar
Nice results here with a P1SC .. http://forums.corvetteforum.com/perf...d-6-speed.html
Old 01-08-2009, 07:15 AM
Originally Posted by cws T/A
Wow, That's an amazing time with just a blower. I'll soon see because I've got a used P1SC-1 ON THE WAY
Now if I can just find someone to help me slide my rack over and pin that darn crank pulley
Old 01-08-2009, 09:06 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Only disadvantage I know of is needing tires more frequently
Old 01-08-2009, 03:04 PM
blkbeaZ28's Avatar
Most of the daily driven supercharged C5's that I see are procharged. I have a Vortech SQ Trim with a very conservative tune and love it but hate it when I have to deal with a belt issue..I know that A&A has designed brackets to improve the original Vortech set up but I really like the Pro Chargers.
Gilbert
Old 01-08-2009, 04:06 PM
BLNLS1/RX7's Avatar
Be careful with a used unit.
Old 01-08-2009, 04:14 PM
The forum member I'm buying it from said he had had purchased it with 6000 miles on it (never installed it himself because he went stroked, H/C route) said he took it to his shop, that is a procharger vendor, and had it checked out and it was good to go. Is there anything I need to look for when I get it?
Old 01-08-2009, 06:11 PM
BLNLS1/RX7's Avatar
Call ATI (1-913-338-2886) with the serial # and find out who the unit was sold to from them and then just check the history of it.
Quick Reply: procharger SC
