Conversions & Hybrids - Trans dapt mounts way off?
xpndbl3
01-05-2009, 08:55 PM
Just put the conversion mounts in my camaro along with the exact same tubular kmember and solid mounts that were used in the last build. The solid motor mount bolt holes are over 5/8" too wide and it seems like the engine is 2" further forward because there is a gap between the trans and the engine with one of the motor mount bolts in place and the opposite side bolt laying on top of the solid mount bolted to the kmember. Not sure how these things could be off that badly. Anyone else have issues with the transdapt engine mounts? This is in my 84 camaro btw.
i had the same issue. its only off the thickness of the plate. but only one mount will bolt in.
i took my old small block solid mounts and bolted them in the car. bolted the plate onto the block and set it all in the car. tack welded it in place, then welded the entire thing up. works like a champ.
xpndbl3
01-05-2009, 11:36 PM
that's probably the route i'll have to take especially since it seems like the motor is 1 inch too far forward as well. If I spend more than a few hours on it, I'll just resell them and install a front plate if I get mad enough. :P No sense wasting time on it if they won't work.
Just wondering if you had any pics of your setup and where the mounts ended up when you welded it all?
this is all i have on the computer right now, and the motor is out of the car. building a bigger animal right now.
the motor is set back more than the small block was. it ended up being a lil tight on the bellhousing bolts. ive been able to drop the tranny and whatnot, its just not super easy with the solid mounts.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
