tire size + stock gear question
Old 01-06-2009, 12:31 AM
SHDY 5.7's Avatar
Default tire size + stock gear question
Any body here ran a 28in tall slick on a stock gear? How'd it work in comparison(if u have)to a 26in tall tire?
Old 01-06-2009, 03:13 AM
robsquikz28's Avatar
with the stock gear being a 3.23???? and the 28" it could act a little bit more a 3.42 gear which can be better if you spraying the car
edited below (i forgot to add what i was thinking)
Old 01-06-2009, 04:14 AM
lemons12's Avatar
wrong.... if your on a 323 rear end and put in a 28 inch tire its more like a 273.... if you have a 273 and 28 inch tire its more like a 24x's..
i would sugest this... is there a reason your going with such a big tire... im guessing with stock gears you havnt modded the car a lot.. which means you should hook just fine on a 26 inch mt street or something...
Old 01-06-2009, 09:21 AM
SHDY 5.7's Avatar
I have a set of 28s laying around so I was gonna try them. Im not sure what gear is in the car. Its a a4 96 formula. Im gonna buy some 26s for it,just wanted to see if a 28 will hurt me.
Old 01-06-2009, 09:51 AM
ss.slp.ls1's Avatar
It will probably feel a little sluggish with a huge tire.
Old 01-06-2009, 11:13 AM
SHDY 5.7's Avatar
Yeah that's what I figured. I don't wanna open the rearend just yet so ill stick with 26s.
Old 01-06-2009, 12:00 PM
LS1 SPEED's Avatar
I run a 28" tire with a 3.42 in my dad's car.
SS4000 stall
3600ish lbs
H/C setup
1.51 60 ft
The stall would make a difference with gear and tire choices, but if a stock stall the 28 would suck on motor.
on a N20 car you probably see a gain just due to traction
Old 01-06-2009, 01:15 PM
SHDY 5.7's Avatar
It is a n2o car with a small stall 26 to 2800rpm,stock gear.
Old 01-06-2009, 01:17 PM
SS4000 stall
3600ish lbs
H/C setup
1.51 60 ft
yes i had forgot to mention that with a stall with act as a 3.42 gear and be better but would definately suck w/o a stall.
Old 01-06-2009, 03:23 PM
SHDY 5.7's Avatar
So if the car has a stall,a 28 should be ok?
Quick Reply: tire size + stock gear question
