View Poll Results: Which is best for my setup in my 98Z28 A4
F.A.S.T. 92MM
25.71%
Edelbrock victor jr with elbow
71.43%
metal ls6 style like the bbk ssi (ported)
2.86%
Voters: 35. You may not vote on this poll
POLL: Intake manifold on my setup
Old 01-06-2009, 06:42 AM
exodus's Avatar
Question POLL: Intake manifold on my setup
This car will see regular weekend track duty, but remain street driven on occasion.
The setup will be as follows:
iron 408 (all forged and studded)
9.5:1 compression
AFR 225's
single t-76 or t-80 @ aprox 10-12 psi
MAX RPM 7000, AND SHIFTED@ 6200-6500 RPM
Cam is still unknown
I know that there are pro's and con's for all of the choices here, but I am looking for what would give me the best performance for my setup for what I will be using the car for. I know the fast 92 flows a lot of air, and is great for the low and midrange. It is also good for the rpm range I would like to be in, but not sure what design is going to give me the best results for my application.
PLEASE COMMENT ON WHY YOU MADE THE CHOICE YOU DID
Old 01-06-2009, 06:57 AM
crzytown69's Avatar
i say fast because if you change your mind later on like a fiber tuned intake you can always move the fast
Old 01-06-2009, 07:14 PM
1CAMWNDR's Avatar
Go with the single plane. Killer flow, better distribution and a hell of a lot less money.
Old 01-06-2009, 10:19 PM
exodus's Avatar
I like to hear why you voted the way you did, please post a comment up after you vote.
The people that are using the Edelbrock intake on a boosted application, are you having any issues with gaskets?
Old 01-08-2009, 11:59 AM
exodus's Avatar
Please post why you made your choice
Old 01-13-2009, 06:39 AM
exodus's Avatar
ttt...
Old 01-13-2009, 08:18 AM
Tricked-Out-Toy's Avatar
Vic Jr- Cheap, Effective and looks badass
Old 01-13-2009, 09:10 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I voted for the vic jr simply because LS6 wasnt an option. I'd have gone with a stock LS6 over all those options personally...
Old 01-13-2009, 09:11 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Originally Posted by tricked-out-toy
vic jr- cheap, effective and looks badass
+1, +1, +1.
Old 01-13-2009, 12:14 PM
deadhorse66's Avatar
For your large cube application, the single planes such as the victor and the GMPP carb style intake manifolds work very nicely. The only real downfall to them is that smaller cube aps don't move enough air to keep the velocity up at lower rpms. They get a bad wrap from people who put them on a HCI stock cube car because they're simply too much. You're semi-big inch, and you'll be boosted, and thats where those manifolds really shine. Plus FAST wants entirely too much for a manifold that won't out do the much cheaper single plane.
Old 01-13-2009, 09:17 PM
1999FirehawkLS1's Avatar
When your forcing the air in does the flow of the intake really matter?
Old 01-13-2009, 09:34 PM
99bowtieZ's Avatar
Flow rates always matter. The real question is how much will it effect the rest of the setup...
Old 01-13-2009, 09:35 PM
99bowtieZ's Avatar
Vic jr... for the same reasons everybody else is saying it. Its cheaper and will run just and strong if not better than the fast 92.
Old 01-13-2009, 10:15 PM
Absolutely. Ever see a 1000 horsepower forced induction car with stock heads and intake? Things like pressure drop, turbulence, velocity and charged air temperature are all affected by intake manifold design and composition.
Old 01-15-2009, 02:11 AM
Got ya i figured the exhaust side might be more important than the intake side since the air is being forced in instead of the engine vac doing it
Old 01-15-2009, 12:31 PM
They both count just as much as with an N/A engine. Remember that air will always want to follow a straight line as path of least resistance. When you have heads with poorly designed runners, steep short turn radii, small intake runners with inefficient design, etc., all the boost in the world won't make up for what an engine that breathes efficiently will do to you on the track.
Old 01-15-2009, 01:11 PM
sevanseriesta's Avatar
Voted Victor Jr, because well hell Like everone else said what else beats this look
Old 01-15-2009, 02:51 PM
exodus's Avatar
Seems to be pretty one sided. That's good, makes for an easy deciscion. Board hasen't let me down yet.........not going against the majority here either. VICTOR JR. IT IS! Thank you everyone for voting and commenting your opinions.
Old 01-15-2009, 03:27 PM
jfg455's Avatar
single plane has been proven to make more HP than all other intakes hands down. And it gives me a bonner!
Old 01-15-2009, 03:41 PM
theguyulove2hate's Avatar
Where do you get that elbow??
