whats pistons
LS1Tech Premium Sponsor
Check us out!
http://www.texas-speed.com/shop/item...d=107&catid=38
Those are the 2618 forging, which you'll want if you are planning on using a power adder down the road for sure!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Perfect. I'd go ahead and get a steel top ring set for it, and you should be set up nicely!
__________________
