LS7 Head Gakets...
Old 01-07-2009, 07:21 PM
TheBiz's Avatar
Default LS7 Head Gakets...
will they work on a 4.010 bore LS2? I'm looking for a good head gasket, but I'm trying to steer way from a $150 set of cometics. Or any suggestions?
Old 01-08-2009, 09:10 PM
405HP_Z06's Avatar
What head are you using? Are you running forced induction? The GM 6.0L MLS is a great gasket and very reasonably priced. GM part # 12589227
These have a 4.039" bore diameter, .053" thick.
Old 01-11-2009, 08:57 AM
TJ
TJ's Avatar
i have been directed away from the ls7 gaskets because of coolant passages not lining up, but i read several folks run them with success.
an l92 gasket may be a better option for you.
its a 4.09xx-4.10xx bore.
Old 01-11-2009, 09:43 PM
TheBiz's Avatar
Thanks guys going with the 6.0 gasket. I wasn't aware the cylinder bore on that gasket was as large as it was. Thanks!
