injectors
injectors
Posting this in fuel and SC section since it involves blower
What injectors would I need for a H/C A4 C5 with all the bolt ons making 414rwhp (with TC unlocked) if I add a P1SC-1 at 6psi (hopefully 550rwhp)
Dumb Ass Vette Moderator
I also agree with 60lb injectors. 42lb injectors would handle 550 NA rwhp just fine. But in FI setups, the pressure in the intake manifold will be working against the injector and making it not as efficient. 60lb injectors will also give you some room to grow if you want to switch out to a D1SC head unit or spin the **** out of the P1SC
Posted as info by vendor (Not stirring a pot, just trying to verify quality)
"Originally Posted by XtremeMotorsports
I would like to thank you and Jon for helping me figure out this issue.
I would also like to publicly endorse this company and their ability to do outstanding work.
In addition to these injectors I also sent them a set of stock LS3 injectors and had them re-flowed to 60LBS/HR, not only were they professional I had the injectors back within 3 days from the day I dropped them off.
I installed them in a 2008 Corvette we did with a Pro Charger,Melrose Long Tubes,Random cats and X-Pipe,with a magnaflow Cat Back. I have to say this was the easiest car I have ever had to tune. I made 3 pulls and I was done !! The car drove like it was stock again.
If anyone needs any injectors, I strongly suggest you use the Fuel Injector Connection. Thanks again guys !!"
