Sponsored by: DashLynx
help removing bumper lights
Old 01-07-2009, 09:51 PM
IndigoSS's Avatar
Default help removing bumper lights
I fought my damn front bumper lights on my camaro for 2 hours last night and didnt get 1 of them out. I went from the bottom of the car and removed all 3 bolts and everthing and COULD NOT get them to come out. They were damn near all the way out but nothing does anyone have any secrets on getting them out please. thanks
Old 01-07-2009, 10:19 PM
Friedrice's Avatar
I'm guessing your talking about the turn signals. Well you have to take off the 3 bolts and wiggle them upward to the point of almost breaking them. I know I broke my old yellow lights taking them out to put my clears in... But an easy way is to take off the front bumper lol.
Old 01-08-2009, 09:41 AM
IndigoSS's Avatar
thats what i thought about doing is breaking them
Old 01-08-2009, 05:05 PM
GTABurnout's Avatar
I thought you could get to them by removing the headlight. Or is there more trouble after that?
Old 01-08-2009, 05:17 PM
98 WS6's Avatar
Holy crap you gotta do all that to take out the DRL? What ever happened to good old screws?
Old 01-08-2009, 05:30 PM
IndigoSS's Avatar
GTA how did you get your black ones in??
Old 01-08-2009, 10:00 PM
jvillescamaroz28's Avatar
pull you head light
take out screw facing toward back of car
take out screw facing ground
grab small end with 194 bulb in it and use a little force to pull past edge where bumper and fender meet
you may chip corner off.... but youll be the only one to know... you cant tell when its installed
Old 01-09-2009, 09:21 AM
quiet_storm98's Avatar
Originally Posted by jvillescamaroz28
pull you head light
thats basically what i did..it also helps to actually push down on the area of the front bumper where the turn signal screws in and then pull the corner of the signal over that area...its actually really easy once you do it a few times
Old 01-12-2009, 12:10 AM
Z28_LT1's Avatar
did mine today... it popped right out....
Old 01-12-2009, 12:12 AM
jsteele90's Avatar
pull headlight out its a very easy job i think i did my clear corners in like 15 minutes
Old 01-12-2009, 10:35 AM
GTABurnout's Avatar
The easy way, bought the car with them installed...
Old 01-12-2009, 06:25 PM
Z28_Cory's Avatar
Is it easy to just change the bulb??
Old 01-12-2009, 06:27 PM
99FormulaM6's Avatar
i changed my bulb by just taking out the headlight and wiggling my arm in there to do it
Old 01-12-2009, 06:54 PM
Blk98ls1's Avatar
I did this last month. It is definitely easier to take out the one bolt on the headlight assembly and remove your headlights first. Remove the three screws on each turn signal and pull the outer part up and leave the inner part angled down. I also loosened a bolt where the bumper and fender meet. this just gives you that little extra wiggle room. It also helps to squeeze the lip back with pliers right where you loosened the bolt on the bumper. Hope this helps.
Old 01-12-2009, 10:19 PM
SparkyJJO's Avatar
Old 01-12-2009, 11:05 PM
italicizedsponge's Avatar
what i do it pull the front bumper towards me and ease the outside of the signal around the metal piece that gets in the way everytime
Old 01-14-2009, 11:41 AM
IndigoSS's Avatar
changing the bulb does not make the lens clear or black
Quick Reply: help removing bumper lights
