Can big cams set MAP sesor codes?
Old 10-02-2003, 07:08 AM
gomer's Avatar
Default Can big cams set MAP sesor codes?
I have searched around and found some older post where some people thought that a large cam would set a p0106 MAP sensor performance code. Check out my thread from yesterday describing my problems and tell me what you think.
MY MAP SENSOR POST
Old 10-02-2003, 09:18 AM
LS1Tech Sponsor
Slowhawk's Avatar
Default Re: Can big cams set MAP sesor codes?
Never heard that before I've never had problems with mine and have never dealt with that prob.
Old 10-02-2003, 09:23 AM
gomer's Avatar
Did you read my other post? I'm wondering what you think might could be the problem. Do you know what parameters the MAP sensor output must adhere to during operation in order to avoid setting the SES and causing the p0106 code?
Thanks
Old 10-02-2003, 10:57 AM
NoGo's Avatar
It is set by big cams at start-up. You have to alter the lower VE table to get the car to start properly and not set the code.
Old 10-02-2003, 11:04 AM
gomer's Avatar
Please tell me more! What exactly causes this on start up? Is it some type of pressure spike in the intake caused by overlap? What type of correction needs to be made to the lower VE table. THanks so much for the info!
Old 10-02-2003, 02:20 PM
gomer's Avatar
Anybody else ever seen this?
Old 10-07-2003, 07:45 AM
Red Dragoness's Avatar
I did. I just got Heads and a bigger cam. I have 3 error codes....P0106, P0530(took out A/C) and P0101. What concerns me most is the car is surging. That gets a little scary when I am trying to park it in a small garage. Does anyone have any idea why the car would be surging?
Old 10-07-2003, 07:52 AM
FEAR THE LS1's Avatar
Check your IAC #'s while your idling and while you are in 1st trying to park etc. If your not getting enough air your motor will surge.
I like my IAC's at 50 in park/neutral, when you put the gar in gear it should raise to about 80. An easy fix for this if all your tuning is good is to enlarge the hole in your throttle body very little.
I was getting the P0106 MAP sensor code after my heads and cam install as well. I kept thinking I had an intake/vacuum leak. Checked everything for leaks and found none, I even replaced my MAP sensor with a new one. I gave up on it because my car was performing better than ever. After a couple weeks the code disappeared from the PCM on its own.
Good Luck,
Lee
Quick Reply: Can big cams set MAP sesor codes?
