coolant path?
Old 01-08-2009, 04:45 PM
DCsLS1's Avatar
Default coolant path?
Anybody know the path in witch the coolant flows through the engine? ive searched this and couldnt come up with a diagram or anything so if anyone knows please share the info thanks
Old 01-09-2009, 02:12 PM
DCsLS1's Avatar
really no one knows?
Old 01-09-2009, 02:27 PM
vettenuts's Avatar
Short version, coolant goes from pump into block around cylinders to the back of block then up into heads to the front of the heads and out to the thermostat. That's why the rear two cylinders are usually the first to let you know you have tuning issues.
Old 01-09-2009, 02:52 PM
DCsLS1's Avatar
thanks, and i was also wondering about the throttle body coolant does some flow into there after it has gone through the heads?
Old 01-09-2009, 06:59 PM
vettenuts's Avatar
Yes, that is one path as it leaves the heads. Guess that's why I said short version above, as the heater core is another diversion as well.
That is also why you have to be careful with Cometics, they are not marked front and back so you have to go by the coolant hole alignment. Some guys have installed backwards and the rear cylinders starve for coolant as a result.
Old 01-09-2009, 07:00 PM
DCsLS1's Avatar
cool man thanks for the info
Old 03-01-2010, 01:00 PM
infamous ss's Avatar
my ls1 is leaking coolant from the back of the engine on drivers side, i checket the freeze plugs and they seem to be fine, can any one help me, its a 99 ls1 . thanks
