What is your Estimate.
Old 01-08-2009, 07:00 PM
RARON455's Avatar
Default What is your Estimate.
any good guesses, I currently have my car down for some swappin, I have had my 69 at the track many times, but not this one
its a 98 T/A
Stock bottom end
TSP stage 2.5 5.3 heads, milled to 59cc
233/239 cam .595/.603 112 Degree lobe sep XER lobes
Ported fast 92/ PTM 92 TB
Volant Cold air intake
american racing long tubes
TSP rumbler cat back
9" with detroit locker 3.70 gears pst driveshaft
T-56 (built by sixspeeds inc.)
ram clutch set
and a 175 shot of spray
MT et slicks
I have the pro 5.0 shifter and am pretty good with a stick, so what is your guess, I will run it when I am done and have it tuned so I WILL post up my results.
RARON455 is offline
Old 01-08-2009, 08:34 PM
Carter01's Avatar
How about suspension, how about a tune? If you have suspension and the car us tuned right, the car with a good launch cutting around a 1.5-1.6 60ft I think you should run 11.40s n/a and 10.50s on the juice. You stated you were a good driver so these numbers are with you driving it like you stole it! GL
FWIW - I like your signature, really makes one think.
Carter01 is offline
Old 01-08-2009, 09:07 PM
Navy David SS's Avatar
Wrong Section.. post it here
https://ls1tech.com/forums/drag-raci...-ask-here.html
Navy David SS is offline
Quick Reply: What is your Estimate.
