Advice Please Guys Help
Well i just broke my 2nd 10 bolt, and now buying a 12 bolt Moser. Im gonna get the heavy duty posi unit, TA cover, 33 Spline Axels, and Working Abs. Im gonna get it for 2275, which is not bad. I was wondering what gear ratio I should Get? My car is a 95 TA 6-speed, with a 383 stroker, with heads(AFR 2.02/1.60) and cam (LT4 Hotcam) everything else is done! All possible things, it has em'. Im running 315/35/17 rear tires, and i want to go through the 1/4 in fourth, not 5th...What gear ratio do you reccommend? Thanxs guys...also is there any problem with these mosers i should expect? gear whine? or anything? thanxs, very much appreciated
Re: Advice Please Guys Help
What are your trap speeds now and what do you have your redline set at? Just follow the link for an excellent calculator where you can plug in all the variable of tire size, redline, and gearing in order to find out your speed in each gear. Then make your decision from there .
